nuts4hotwheels
- Feb 4, 2015
- 85
- 13
- 2006
- 5.7L Hemi
My rear driver side brake caliper is not fully retracting. It’s not locked up, but it makes a squeal noise like the pad is lightly rubbing the rotor. I removed caliper and the pistons pushed in easily. I greased guide pins and reinstalled, but it is still doing it.
I’m thinking that it may be the brake hose collapsing internally and allowing fluid to flow easily in one direction but not the other, but usually it will completely lock up.
I think that I will replace the hose and see if it helps and then replace caliper as next step. I just want to get a second opinion for my fellow ram owners.
