kentm
Hey Guys/Gals,
I’ve been having an issue with my aftermarket brake control for some time now. When I plug my trailer into the seven pin connector the brake control lights up as expected. When I press the brake peddle the brake control isn’t recognizing it so the trailer brakes don’t engage. If I use the manual slide on the brake control the trailer brakes work as expected. Using a test probe light I can see there is power going into the brake control on the black wire. Power coming out of the brake control on the blue wire when the manual slide is engaged. However, there is no power coming in from the brake light switch on the red wire when the brake peddle is pressed. The brake control is a
Tekonsha 9030 Voyager Electronic Brake Control. I tried replacing the brake light switch but that hasn’t helped.
Note: The truck and trailer’s brake lights DO work as expected.
Any thoughts would be greatly appreciated!
Kent
Kent
