Brake tube, what is its purpose?
Discussion in '2nd Gen DIY' started by glipman, Feb 22, 2017.
  1. glipman
    glipman Junior Member
    24
    23
    Jan 4, 2017
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    [​IMG]
    [​IMG]
    What is the purpose of this tube? It is broken on my truck and was leaking water after being moved around
    "inspirational quote" - someone
  2. Ram444
    Ram444 Senior Member
    191
    86
    Jul 12, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    I could be wrong but it looks like the actual brake line. ????? Check your brake fluid level under the hood.
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,459
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    That is your brake line that goes from the frame to rear axle. Brake fluid is clear almost like water. You probably don't have any rear brakes, you might also have a burned out brake warning light in the dash.
  4. glipman
    24
    23
    Jan 4, 2017
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    The light works and it has brakes. I followed the line and it's plugged up at the body. It is a rubber hose that runs into the block for the brake lines
  5. jwheeler
    jwheeler Senior Member
    1,536
    389
    Oct 11, 2014
    Washington
    Ram Year:
    2010
    Engine:
    If you brakes still work, it is likely not a brake hose. Probably axle vent tube. Are you sure that it is number 7 in the pics? And that it doesn't actually go on top of number 8? That is where the vent goes, it is not in those pics
  6. jwheeler
    1,536
    389
    Oct 11, 2014
    Washington
    Ram Year:
    2010
    Engine:
    [​IMG]
    1 is a brake hose. 2 is the axle vent. Just tie it up where water won't get in.
  7. dudeman2009
    22
    1,459
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    Jwheeler found a good diagram for it.
    Part 7 in the first diagram is a brake line. Part 8 is the axle breather that also has a rubber line attached.
    If the tube you're talking about is for the axle breather, just zip tie it to the top of the frame rail or something where it wont get caught. If there was a lot of water coming from it (I mean more than a few drops or a quick stream) you'll want to consider removing the differential cover and replacing the differential oil.
  8. CostaRam
    CostaRam Senior Member
    264
    68
    Dec 26, 2016
    Costa Rica
    Ram Year:
    Engine:
    Number 7 comes out of the axle thus must be the axle breather tube.
    In any case there should be NO water inside!
    You should check your axle gear oil!
    Chris
  9. glipman
    24
    23
    Jan 4, 2017
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    Thank you very much! It was the differential breather. Boy there's alot of nastiness in there, a good quarter cup of water came from the pipe alone time.to clean her out and lube it back up
Share This Page
