Can it be towed behind rv?
Dmopar74
Can a 2015 1500 4wd 8 spd be flat towed behind a motorhome?
mtofell
Assuming you mean with all 4 wheels on the ground? Your best resource is the owner's manual. There should be info in there that specifically addresses this. Most vehicles "can" be towed but some/many require modifications to do so.
MADDOG
Out Exploring Arizona
^^^^ this ^^^^
If you have a N setting on the transfer case this is a hint that you can but you should ALWAYS verify you can flat tow referring to the owners manual.
tncruiser
kingston tn
5.7hemi
also remember your MH capabilities if its a gas MH usually they come with a 5000lb hitch and a 4wd 2500 is gonna weigh a whole bunch more.
brianj
Orca
