Check engine code 219B permanent
Jsimon34
Lutz, Fl
Anyone on here know anything about a check engine code 219B showing permanent on 2013 1500 hemi? My light has been coming on and going off for about 2 weeks now. Had it checked out and everything was good. Not thinking it's serious, more annoying really. Just wanted to see if anyone had any experience with this code and what they did to get rid of it? Thanks in advance
Jsimon34
Jsimon34
Lutz, Fl
Says bank 2 air/fuel ratio imbalance
Jsimon34
Jsimon34
Lutz, Fl
My fault.... I posted that before I read what You posted
Gordon
I had the same code
I have a 2013 ram 1500 express had the same code. I am at the dealership now. After diagnostics they say could be a false code but worst case a leak at cyclinder 2.
Jsimon34
Jsimon34
Lutz, Fl
I'm taking mine Friday...had diagnostics done somewhere else and they said everything showed up fine.... light went off for a few days, then back on since then.... let me know what they say your issue is..... thanks
Jsimon34
Jsimon34
Lutz, Fl
I just got back from dealer.... PCM needed an update and they say that took care of the issue...if not, it's on them....
Jsimon34
Jsimon34
Lutz, Fl
So the dealers little pcm update didn't work.... my truck has been at the dealer since last Thursday with them trying to figure it out because the dealer and Chrysler have never had this code pop up before according to them.... at Chryslers request they basically took half the engine apart and discovered something.... not sure what exactly, but they are putting new cylinder heads on it under the powertrain warranty..... so I'd be careful when someone tells you this code may be a false reading or isn't anything to worry about ....
Jsimon34
Jsimon34
Lutz, Fl
Finally got my truck back after its 5th trip to the dealer for this code..... and after Chrysler told them to update the computer, change a cylinder head, do an "extensive" injection cleaning, tune up (only paid half price for that) and finally replaced cylinder 2 injector, the CEL has not come back in after a week..... praying they finally found the problem...... only paid for the 1/2 of a tune up bc they were replacing the other plugs with the cylinder head change..... EVERYTHING else was on Chrysler..... $150 for probably $6,000 worth of parts and labor even tho most of the stuff was not warrantied... I'll take that any day.....
