Zach Carlson
I'm running a 2013 ram 1500 5.7. Mods include K&N cold air intake, 90mm throttle body, BBK shorty headers, muffler delete(factory cats and rear resonators still installed), and a diablosport predator 2, 91 octane can tune.
I started getting a cylinder 3 misfire code. Code only comes up after getting on it a little. As long as I drive easy, no problems. This code has only be recently.
Before this code, I would also get a check engine light once every couple weeks. Each time I scanned it I got different codes each time. Everything from vehicle primary speed sensor to throttle control erratic voltages.
Does anyone have any idea why the random codes? And also, why only when after hammering on it?
As long as I drive easy and never get into it I won't get codes.
I'm not trying to replace stuff that isn't bad and I feel if these things were actually bad I'd see the code several times.
Any thoughts would be appreciated.
