alpinepeople
- Dec 6, 2015
- 1
- 0
- 2004
- Hemi 5.7
Locating Sensor Opp
Hi all,
I have had the truck for less than 4 months 04 2500 HD 5.7 @219,""" miles. 4x4. Clean truck, has obviously been maintained well. Have not had any real problems. The check engine came on and went into the local APS and had the codes read. Came back as P0113 and P0141. 0113 seems simple enough. IAT sensor is easy enough to swap and is only $14. Will be picking up the IAT tomorrrow. However, the p0141 comes back to the o2 sensor (downstream) from what Ive gathered. If I remember correctly is was Bank 2 #2. I will pick up one no problem, but do not know the exact location of the O2. Does it happen to the one threaded directly into the cat? Doesnt seem to be any info online about location. I need to change it asap because i will be moving to an inspection state soon. Thanks in advance.
Hi all,
