COLUMN SHIFTS SAYS REVERSE
cmore2500
texas
6.4 hemi
I bought a 2014 2500 and the truck kicked hard from 1st to 2ndf rhen began slipping and skipping gears. Checked fluids and was down at least 2 qurts. Where did it go? i have trace of leakage.
Put in oil and still the problems occurred. Code came up PO 750. I replaced shift solenoid pack. filled tranny and looked at console which now says its in reverse and will not start. Linkage verified by removing cable and manually shifting solenoid pack gear. If this reoccurs next up will be to replace valve body. Any ideas?
Badfish379
Indiana
Having very similar issue right now. Just posted about it.
Papa Red
Papa Red
Nebo, NC.
Welcome to the forum.
Post your question in the 4th generation section and you will get some help.
Red
