Big Boi
I will be having the Belltech 963SP trimmed to a 3/5 drop, and installed this week (Tropical Storm Permitting). I ordered the Viar 10002 system to supply air to my air horns and possibly to the AirLift helper springs Part# 60824.
A)
I can go the easy/cheap route and run the schrader valves from the bags to the licenese plate holes like most do. But also add a quick connect fitting to the onboard air system. I would keep a coil hose like THIS in the cab for quick inflation of the bags, tires, etc.
B)
Tap into the onboard air system and add one SMC 3/8 valve for filling and another for dumping. Add a gauge and a swtitch inside the cab.
C)
Use the FireStone 9257 automatic valve tapped into onboard air with no gauge
D)
add the AirLift 25804 and leave the onboard air for just the horns
A)
B)
C)
D)
