Confused about lift and rims
jpleasant
Cummins 5.9
Okay this is the lift on my 08 ram 1500 2wd... Thats just the front in the picture.
I have 35x12.5r18 tires and rims on it. I want to go up to 22's with 35's is that possible with the lift i have?
[/ATTACH]
Lil_Ram
Power tech 3.7L
How much lift do you have and by swapping wheel size diameter won't affect that but the backspacing will
J
jpleasant
Cummins 5.9
I was told I have like a 3in a half or 4 inch lift i bought it the way it is and i'm not that good telling the lift size.
Lil_Ram
Power tech 3.7L
Get the lift coils from maxtrac or RCX if you want more dot do that BL
J
jpleasant
Cummins 5.9
so by the that im assuming the 22' inch rims with 35's wont fit my current setup. I dont want to fill the wheel well I want it to still look lifted
Lil_Ram
Power tech 3.7L
No the tires will still be 35" which you said you had so it'll still look lifted
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Looks like a 3" leveling kit to me.
You're running 35's already so as long as the 22's aren't ridiculously wide with a negative offset they'll fit no problem. Wheel diameter doesn't mean anything in the grand scheme of things. Only the wheel width/offset and tire diamater/width matter. You haven't really given us enough information to give you a solid answer. We need more info on the wheels.
Orca
