Cooling Fan Shoot-Out!
chrisp2493
Always Modding
Warren, OH
392 Hemi
I love engine masters! Those are quite surprising results, maybe I will look into an efan sometime soon
Jwithing
STL
Wow, thanks for the video, glad I removed my clutch fan this weekend lol.
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Ordering my eFan tonight :)
chrisp2493
Always Modding
Warren, OH
392 Hemi
What's a good brand efan to run? And how much does it cost to upgrade to these?
DRkNESS
South Jersey
I second the best brand of Efan to run also question please.
F.O.F
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
just remember your ram has a clutch fan so you only lose 14 hp not 30hp
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
Oem mopar fan is best...when I installed mine I also did the ATI dampener pulley and 180 stat...this video is proof that these mods add horsepower and torque. Highly recommend it!!! Below is a great thread where many including myself have shared part #s and pics. The oem mopar fan bolted right up in my 13 and was plug and play....it's also very quiet! With hemifever tuning truck runs at 185 consistently!:roflsquared:
http://www.ramforum.com/f75/how_v6_efan_conversion-17595/
chrisp2493
Always Modding
Warren, OH
392 Hemi
I have an 03, still a good choice? I've been looking for an old mark viii fan, summit also sells a dorman replacement fan. Is that any good?
DavidN
Central Florida
Not very familiar with that e-fan conversion on our Hemis - so maybe a dumb question...
Will the e-fan replace the ac fan?
And why not use that existing ac fan? I mean it's already there...
Jwithing
STL
My understanding is the hemi's already have the full size efan that the V6 gets plus the clutch fan. With the 180 thermostat and a tune to lower the efan settings, you can run with just the efan no problem (unless your constantly towing heavy loads?). I did this and my coolant temp stays 186-188
chrisp2493
Always Modding
Warren, OH
392 Hemi
The e-fan replaces the large clutch fan on the front of the engine. The video in the op shows that the fan is causing approx a 15hp loss where an electric fan may lose a hp or two.
crazykid1994
On the newer trucks having only 2 wires to the AC fan is it possible to do this still or would one have to get a controller and wire it in for a low speed and tie the AC in on the high side with the controller?
DavidN
Central Florida
So much I understood.
My question was more - doing the e-fan conversion and getting rid of the clutch fan, will the e-fan replace the ac fan and if so why not just use the (already built in) ac fan. Not efficient enough?
DILLIGAF
Canada
Just get a tuner with a custom tune and run the AC fan with a 180 stat. Money is way better spent that way...
Hipps2000
Hemi 5.7l
Some do...look in the thread I posted pics of the 2 side by side....I went with the v6 fan because it comes with a small plastic shroud as well as a clip to lock in upper hose. I went with the oem fan some do the ttyc or doorman...they are cheaper but the oem in my opinion is way to go!
savage_46
Alaska
6.4 swapped
Guess this is one of the next things I'll do. Give me a reason to spend money elsewhere while I decide on a supercharger. Pretty good info though
