Crank shaft position sensor (CSPS)
KillRbee18
Port Orchard WA
I am thinking it is time to change out my CSPS, because there is no sound when attempting to turn over my motor (dead -- no sound). As it looks right now, the ignition switch seems to be okay (seems). I would like to ask my Dodge Brothers how hard is it to change it out? I know in the past, it can be challenging; from changing one out on a jeep Cherokee. Is this an item that should be changed at a local service garage? Will I need special tools to do it? Beside learning how to do yoga (to fit myself inside the motor), is there anything else I should be aware of? Any information will help --- thank you
