Daniel J
I have an 02 4.7 that I bought New. Now 176 K and it still runs like a striped ape. Problem !! 3 years ago I did a preventative maintenance. I replaced the complete timing sets chains, sprockets and guides (Cloyes) along with a new water pump. It runs great as usual, Since then I have replaced everything Radiator, clutch fan, Another water pump. This time Delco premium. All hoses and belts.
Problem?? Drive easy to normal it stays at the middle mark on the guage.! Shove your foot into it and clean out the cobwebs and the temp guage will be in the cold mark. The heater will blow cold air until the temperature comes back up to where it’s supposed to be.
No it doesn’t use any oil or coolant period. No head gasket leaking it been tested multiple times. It doesn’t use a drop of oil or coolant in 3,000 miles.
What’s the problem???
