DIY taillight tinting
kml9491
Has anyone done this to their 4th gens? Contemplating doing this since my truck came with OEM LEDs. Any pointers or advice?
icywhite
Sand the taillight get the paint, paint then clear coat it
Ian
Port Orchard, Wa
6.7 Cummins 24 valve
I did mine not too long ago with VHT Nite Shades. Pretty simple process. Remove the lights, mask off the reverse area so you don't back into **** at night. Clean the lights with mineral spirits then 2 or 3 LIGHT coats of VHT to get complete coverage. I went light to remain legal in my state. After the VHT dries, start coating the lights with a clear coat of your choice. I did about 10 coats with a couple minutes dry time between coats. After the clear coat dries, wet sand with some 2000 grit sand paper and machine polished to a shine. Cost me about $15 in materials and a couple hours of my time. Let me know if you have any questions, I've done a bunch of these and so far they've all turned out great.
kml9491
kml9491
Those look good! What did you polish them with?
Ian
Port Orchard, Wa
I started with a medium abrasive cut compound, then up to a medium swirl remover, next a light swirl remover, finishing glaze, then finally a sealant. All done with a Porter Cable 7424xp and Pinnacle XMT products.
brownsanta
HEMI 5.7L
you have a pic with the lights and brake lights activated?
R.L.K.
Bristol , Tn.
Man these look Fantastic !
I'm gonna do this , as soon as it warms up !
CHTexas
I just tinted and color matched my tails. I went just a bit lighter in the center of the tail and the light output is near identical to OEM. I'm done going too dark and getting hassled on my weekly commute.
Sent from my SM-N900V using Tapatalk
Ilo670
