Drag link send stuck
Mazon1x
Virginia
5.9 gas
Yup can't get it to come out . Tried beating , torching , prying can't get it out . The bottom end popped right out . Any tips would be amazing !
u2slow
BC, Canada
Cummins 6BTA
A sharp rap with a heavier hammer on the SIDE of casting/forging the tapered end is stuck in.... Normally pops it loose.
What you're doing is distorting the roundness of the hole for a split-second which breaks the grip.
Hope that makes sense.
Daw14
Old fashioned pickle fork
u2slow
BC, Canada
Cummins 6BTA
Pickle forks usually wreck the boot or the joint. Not cool when I get most of my parts from donor trucks.
tjfdesmo
AZ
^^^While apply force with a bar. And make sure you use a BFH and swing it like you mean it.^^^
M
Mazon1x
Virginia
5.9 gas
Ended up getting it out with the pickle fork with a sledge lol now I'm at a new problem , can't get the new one in because of that part . Only reason I got the old one out. The joint had came out completely. Which gave me room to get the old one out . Been prying and heating this part with no movement
u2slow
BC, Canada
Cummins 6BTA
Those cone washers are very difficult to dislodge.
Try a good soak with penetrating fluid, and whack with hammer horizontally where I put red dots. Rotor and caliper bracket probably have to come off. 20210606_160303~2.jpg
M
Mazon1x
Virginia
5.9 gas
Try a good soak with penetrating fluid, and whack with hammer horizontally where I put red dots. Rotor and caliper bracket probably have to come off. View attachment 249870
I'll try this Tuesday ill be busy tomorrow. I'll. Try it without the wheel and rotor i had and hit it that way . I just figured I could leave everything unjacked and taken off if ibdidnt have to do it lol ill update Tuesday night
Daw14
Penetrating oil will help .
tjfdesmo
AZ
On medium/heavy trucks with cones on the axle flange we would strike the center of the flange with BFH to shock them loose. Maybe drive on an impact socket over the studs? Air hammer with blunt bit can also be handy.
u2slow
BC, Canada
Cummins 6BTA
On my full-float diffs with the cone washers, I strike the sides/edges of the axle flange at each one to pop them loose.
M
Mazon1x
Virginia
5.9 gas
Ended up figuring it out didn't need to take the nuts off at all. Just had to turn the wheel lol I'm learning as I go with this stuff lol
