edge insight cts
Status
Not open for further replies.
mattman_13
Got the edge insight cts from my old diesel truck. It works on any vehicle with an OBDII port although the pids it will pull is dependent on the vehicle.
I updated it recently and it does work with my 2012 ram showing engine parameters. I don't remember all it showed as I got a diablo trinity.
On my f250 psd i could use it to change tire sizing and monitor egt, eot, ect, air intake temp, boost psi, map flow, rpm, speed, and has a mileage coach that would show fuel consumption. With mystyle from edge you can change the back ground images and make a custom look to your gauges. Just look up on the edge website for further information. I also have the piece that mounts this gauge to the pods for the attitude monitors. Ill throw in for free if someone buys both. It mounted up and look super clean with the pod and the pod adapter in my f250.
Asking $350.00 shipped with egt probe (mostly pointed towards diesels in this sale) and adapter for attitude mount or would do 330.00 shipped for just the unit and 40.00 shipped for just the egt.
Only negative is I don't have the software which is downloadable and needs a mini usb to regular usb to hook up to your computer. Also some insulation was scratched when pulling through fire wall. A picture of the damage is included
Thanks for looking!
ramhunter9
P-Star Jeep Wrangler
Thanks for following the rules .. GLWS
Bump
Status
OasisNinjaBat
