[emoji15]Hemi Tick or Broken Bolt?[emoji848]
Ghost2013SCC
Just started this morning. 2013 Sport w/72k on odometer. It'll go away after it warms up and drive off for a minute or less. What y'all think??
https://youtu.be/TzydIBNRfio
Golden cobra
Most likely a broken exhaust manifold bolt or possibly even a couple
Sent from my SAMSUNG-SM-G930A using Tapatalk
Ghost2013SCC
Ghost2013SCC
That's what I'm thinking. The tick would remain while driving if not mistaken.
Golden cobra
If the sound is going away after about 30 seconds or a minute it's most likely a manifold bolt. The manifold will heat up and expand enough that it will actually seal the gap
Ghost2013SCC
Ghost2013SCC
Now the question is new bolt(s) with powertrain warranty or headers...[emoji848]
Bird
Phoenix AZ
Wait, that's covered under warranty?
**** mines been broken for months, I was just too lazy to fix it.
Ratket
Arizona-
If you got to change the bolts - pony up for some headers... do it once and be done-
Ghost2013SCC
Ghost2013SCC
Should be covered under the 5yr/100k powertrain warranty. I haven't contacted the dealership yet.
huntergreen
I have read that machining the headers back to spec will prevent them from warping again.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
5 year 100K power train warranty. Yes, exhaust manifold or its bolts is part of the powertrain because it bolts to engine and effects combustion process. The rest of the exhaust is not covered. :happy107:
michaelrc51
NJ
Absolutely an exhaust leak probably due to a broken stud
Burla
2010 Hemi Reg Cab 4x4
My lifter tick sounded different then that by a lot = another vote exhaust.
Ghost2013SCC
Ghost2013SCC
Another question...
Will my S&B and Magnaflow weld on muffler void this warranty repair??
daveray9
Another question...
From and engineering point of view, there is no way either would warp the manifold which makes the bolts break so in a word .. no.
daveray9
The sad part is, my truck just started doing this yesterday... but the day before I changed the oil and the only filter they had that would fit was a regular Fram... which I typically hate. But I have also heard that the filters if they aren't high flow can get sucked dry from MDS and during initial startup tick when filling up?
Someone correct me if I'm wrong. Just odd timing that the day after the change it starts making a weird tick noise.
Either way I can replace the filter with the mopars I used before or take the truck in. Its a 2012 so its about to lose the 5 year warranty.
Golden cobra
Just take it in and get the bolts replaced
