Engine noise!
ArmyGrunt66
Corpus Christi, Texas
Good morning y’all
I replaced my serpentine belt this morning, not the idler pulley due to I need my truck for school this week and the part wasn’t available in my town until Friday. Anyway soooo at first I was getting a loud whistling or whooshing sound on acceleration now I’m getting a faint whistling sound on acceleration, any ideas? Should I spray belt dressing on the new belt? Is the new shorter belt placing strain on the pulleys that are 11 years old with 77,000 miles on them? I plan on replacing the idler when I have more time. Thanks for any advice.
Kevin
NJMOPAR
Older and faster
ELizabeth, NJ
Why is the new belt shorter? It shouldn't be able to go on If it's too short. Still have the old one to compare?
And a new belt needs no dressing.
A
ArmyGrunt66
Good morning
I figured the old belt would’ve stretched over time, I compared both belts and they looked identical in size, figured maybe the old belt stretched a little bit you won’t see until you install the new belt? Anyway sooo I won’t need to use any belt dressing? Great!
Kevin
NJMOPAR
Older and faster
ELizabeth, NJ
Can you hear the noise giving it gas in park or just while moving? If it's there in park, have someone rev it while you try to pinpoint the location.
A whistle could even be a vacuum leak or the air tube loose at the throttle body.
Travelin Ram
One way to diagnose the noise is remove the belt and run the engine beltless. Briefly, because the water pump won’t be turning. But you can do it long enough to determine if the noise remains, which will tell you to look elsewhere like intake leaks.
A
ArmyGrunt66
Will do, thanks.
Kevin
A
ArmyGrunt66
Will do this also, thanks
Kevin
Michigan BIGHORN
U.P. Michigan eh
5.7l Hemi (obviously)
And if you ever feel the need to put anything on your belt use Armor All not belt dressing and even that's not recommend it's only a bandaid. Belt dressing hardens, glazes and cracks with time, Armor All just dissipates plus it conditions the rubber a little in the process. Again though I don't recommend any of it.
A
ArmyGrunt66
Good morning
Funny thing is I hadn’t put anything on my serpentine belts in over 20 years, usually replaced the belt as part of periodic maintenance. This time I heard a noise and figured I’ll put some silicone spray on the belt, noise went away, Binged for information and saw it’s just a bandaid, next day the noise came back, inspected the belt and felt crustiness on the ribbed portion, went and bought a new belt and replaced it already, I don’t think I’ll put any substance on any of my belts, never really used belt dressing as a habit.
Kevin
Orca
