Engine Wont start. All panel and lights work
duckewes
engine wont turn over. Just clicks once when i turn the key. Died on me going down the road. Checked battery, seems to be fine. Check cables and they are good. All fluid levels were good. Reset PCM and check fuses, they were all ok. Im stumped. Need help
2013 black Crew Cab Express
When ever that happened to my vehicles I would turn the headlights on and then try to start the car. If my headlights did not dim than I would clean the battery terminals and both cables. Most of the time it worked for me. You may want to try that first.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I'd check grounds, fuses and relays.
D
duckewes
ive checked battery connections. They are clean. Also looked through all fuses, grounds, and relays. They all are fine.
Gecko
NJ
5.7L Hemi, 8.3L V10
I would check your fuel pump. I had a similar problem a couple months ago. All electronics worked fine and the truck would turn over but not start. I had no fuel pressure and it turned out to be the pump.
