Etorque not shutting down
roscoepm
Palm Coast Fl
Hi,
I bought a used 2021 Ram 5.7 etorque a couple of months ago and it was shutting down and starting at stops. Now it doesn’t shut down at all. Any thoughts? Thank you in advance.
turkeybird56
Central Texas
Me personally I would be happy Neva worked but:
There is supposed to be an on/off button. Is it jammed in? Maybe fuse blown ref that button or system operation? I would wonder if there is a specific fuse/relay that controls operation. Just thinking out loud.
If u not find maybe a simple fix and u like that option/system might be a dealer trip then
KeithP
Hemi 5.7 VVT
It won’t shut off if the climate control senses it needs the engine running to maintain cabin temperature (A/C compressor running or heater coil water flow), or you have tow/haul engaged, or if you’re in manual shift mode.
