Thorbeast
2016 Ram 2500 6.4 big horn
Recently put in an RBP 6.5" Lift with transfer case indexing ring.
My mechanic noted that when the suspension is fully extended, like when you lift the truck by the frame rails, the front drive shaft hits the exhaust. Temporarily he disconnected the driveshaft while doing the job, set the truck on the ground and reattached it. It clears when the weight of the truck is on the wheels.
Is there any known bolt in kit to make the exhaust clear that? Otherwise we have to disconnect the driveshaft anytime we put it up on a lift. If not, I'll just have someone custom modify that section of the exhaust.
