Exhaust manifold bolts
Randy1
I have a 2018 Ram 1500 with a 5.7 hemi with a build date of 1-18. Does anyone know if the exhaust manifold bolts are the same as the 2017? I know they made design changes in June 2018.
Thanks
Torqued
Iowa
From what i was able to find is that the bolts are the same from 2012 - 2024.
I could be miss lead. Sometimes it’s a rat race trying to track down what should be simple to info!
This website is where i got my info. And the part number is the same all the way through.
Part # 6510140AA
R
Randy1
Thanks Torqued, Doorman list the same kit for 2017 and 2019 but nothing for 2018 unless you buy the full gasket and bolt kit. The Mopar site I looked at shows additional bars on the top and bottom os the manifold on the 2018.Definitely confusing.
CamperMike
Peoria, IL
My 2018 had the older style setup. If it hasn't been changed it should be the same as 2017.
