Foam Cannon
Discussion in 'Detailing' started by 2015RamWV, Jan 9, 2017.
  1. 2015RamWV
    2015RamWV Junior Member
    24
    11
    Jan 9, 2017
    Ram Year:
    Engine:
    He is 5.7
    Was looking to get some input on if people are using foam cannons on their truck and if so what brand?
  2. bhonshell37
    bhonshell37 Senior Member
    44
    628
    133
    Dec 15, 2016
    Ram Year:
    Engine:
    Go to Autogeek or Autopia or Detailed Image. I have a Chemical Guys foam gun which attaches to a garden hose. Also look up IK multi sprayer and foam sprayer. Each of these are around 15 bucks.
    Sent from my SM-T550 using Tapatalk
  3. bhonshell37
    44
    628
    133
    Dec 15, 2016
    Ram Year:
    Engine:
    MTM is a top shelf brand with plenty of positive reviews
  4. brandonjansen
    brandonjansen Senior Member
    1,689
    899
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    I use an Adam's Polishes foam gun and would definitely recommend it. Makes washing faster and easier while cutting down on surface scratches. Plus it's just fun to use.
  5. Andrew09HEMI
    Andrew09HEMI Senior Member
    812
    254
    Feb 26, 2014
    Ram Year:
    Engine:
    Also have Chemical guys foam gun for regular garden hose and like it. Looking forward to getting pressure washer so I can't get the cannon but the regular does the job. Especially helps when you have areas you need to soak like bumpers for bugs/tar, heavily soiled areas from road grime or salt and to give a nice amount of soap for lubricant to avoid scratches/swirls from cleaning. Can't really go wrong with any of the name brands, all work the same
    THETANK likes this.
  6. 2015RamWV
    24
    11
    Jan 9, 2017
    Ram Year:
    Engine:
    He is 5.7
    Thanks guys
  7. Sswyers
    Sswyers Member
    23
    56
    Mar 12, 2015
    Ram Year:
    Engine:
    So the cannon works better than the gun tho I'm assuming?
  8. 00R/T
    00R/T Supporting Member
    1,448
    893
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    It does, but I use my gun pretty much exclusively now. The cannon is too much of a hassle and the gun works well enough.
    Andrew09HEMI likes this.
  9. Sswyers
    Sswyers Member
    23
    56
    Mar 12, 2015
    Ram Year:
    Engine:
    Ok awesome goo to hear I'll just get the guy I guess and hand wash for the real dirty days
  10. 00R/T
    1,448
    893
    Apr 18, 2016
    CT
    Ram Year:
    Engine:
    I still always hand wash. I just use the gun to float off as much loose dirt as I can first because then there's less there for me to drag across the paint.
Share This Page
