I know who they are. I know they are credible. I also know that this was a test designed and run for a tv show....One brand of engine (GM), controlled atmospheric conditions (A/C dyno room), open-air mounting (not under a heat retaining hood), fixed ignition timing (29deg), operator adjusted ratio, given load setting.....Knowing that "octane" is a rating related to the fuel's ability to resist knock, it's no surprise at the results. In the real world where knock sensors add to the huge stream of data controlling fuel ratios, spark timing, valve timing (on some engines), and even speed of throttle inputs (drive by wire), the fuel's ability to resist knocking affects the power output of the engine. Heat, air density, air temp, load...so many things...Will cause the engine to want to knock at different points with different octane fuels, causing the engine management systems to make adjustments that affect power levels. So, for what the video tested, it was spot-on. For the real world audience, the video was limiting and the results polarized. Typical, given who is producing it. And so I say... You do realize you're arguing about a Youtube video, right?
