For the second time, I jack knifed my trailer into the side of my truck.
JimP
Obviously, I'm not very good at backing up my utility trailer/truck.
This is the second time I jack knifed my utility trailer into the rear quarter panel of the truck. Not very bad but will need a trip to the body shop.
Does anybody make some kind of proximity sensor that lets you know when you're getting too close? Maybe even a voice coming over the radio that says "hey stupid...stop!!!" lol
Ratket
Arizona-
More and more practice- that is your best solution. or a truck with that fancy " backing up " stuff like the ford has for parking trailers. However I would advise learning how to do it and not relying on a "smart truck".
J
JimP
spoon059
Just north of Washington DC
6.7 CTD
Yea, a wife...
Are you checking your mirrors when you back? I can't imagine not being able to see the trailer if it is jack knifed far enough to hit your quarter panel...
JB1
Houston, Texas
Small trailers are a pain to back up, especially if it's on loose gravel
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
Im starting to think its time for you to just hang up your receiver hitch brother, your truck will apparently thank you :crazy:
Kenneth1977
2016 Limited 4x4
Just let your tail gate down so you can see it better :hahano:
SYKRAMMAN
Banned
Jersey shore
06 Mega
Practice, practice, practice, that's all free, no need to waste hard earned money.:driver:
J
JimP
This thread needs pics :buffer:
I think you're right about the pics.
The trailer does sit pretty low and the truck sits high. Still can't believe I did it a second time in less than 18 month. Sheeze.
Drove my previous SUV for over twenty years and didn't do it once. It also sat much lower than my 1500.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I am probably weird I prefer to not use my mirrors. If I look back I am naturally very good at backing trailers. If I use the mirrors I have to really focus and use the bottom of the wheel to do it. I don't know why but always been better at seeing it vs using the mirrors. Since I am only a class D driver it works fine for me. Pros out there with Class A probably would laugh at me. Clean record though and I travel a couple thousand miles a month.
Stefan N
Sweden
2015 Sport
Backup camera is perfect to use, you see when your trailer are an inch from the bumper.
and if you have a 2016 model it can't be that hard to install one
mtofell
If the trailer is small put some extension rod/markers on it so you can see it. The biggest problem I have with small trailers is not being above to see them.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
its tough with small trailers. my utility trailer has a large ramp on the back i can see. use your mirrors and put on some large blind spot mirrors. They really help. take your time and don't be in a rush. you'll get it.
going to a different TV does take some adjustments, but you'll get it, hopefully without any more whammos.
Cmsharp
Rogers, AR
I put pvc pipe on each corner of the trailer, a very slight turn with move a short trailer exponentially. The pipes made it much easier to visualize.
JPT
NY
2015 Big Horn
Do you have any pictures of this?
Thanks
Demon-HeMi
Houston
Tow mirrors folded out, you can see everything you need to with a trailer, here is what i see out of mine, with these you wpuld know long before you crush a quarter panel
Ftank
