Mac1984
Hey how is going. Firstly I would like to complement your guyses community. Although I m new here the numerous posts I have read over the years for different topics have made alot of things easier, or were very educational.
So no as to the actual question. I m currently in possesion of bilstein 5100 front and rear and bilstein rear coil overs (+ 1 inch). Before I install these parts I m debating how to set up my front end. Already ordered tge Zone UCA as I would like to run the Bilsteins at 2.5 in the front and from what I gathered the stock ones will just cause issues. The part I am looking for is the front coil overs that would be ideal to run with the bilsteins at 2.5. Some have mentioned that stock can handle it others have not so I m asking this directly. I refuse to put any stops or bumps in the frame or on the shocks so I m just lifting with coil overs /shocks and UCA. The idea is so that I can run 35 s comfortably with out rubbing when I hit a pot hole or something.
Since I can not find bilstein front coil overs the one that keeps coming up is the eibach pro lift (just the coil overs). Does any of you fine gentleman have any other suggestions and or reccomendations?
