Front mounted hitch
jman86
Hi, new to the site. I have a 2023 ram 1500 classic warlock edition. I was wondering if anyone new if the Draw-Tite Front Mount Trailer Hitch Receiver - Custom Fit - 2" that is for the 2500 would work on the 1500. This hitch doesn't hang low. I understand I would have to modify bumper a little. But curious if it would mount up to the push plates. If holes don't line up possible drill out new holes. My plan is to mount a removable winch, wired for front, and rear of truck also run winch on my tractor. So not really looking for hidden winch mount setup. Thanks in advance
tron67j
Maryland
jman86
jman86
Thank you, I'll be sure to check with them as well.
DA67Goatman
Ohio USA
I didn't like how low the hitch sat, way down at the air dam. I cut the ends off and welded new mounting plates to the end and mounted mine directly to the frame rails. It required a hole in the bumper, at license plate height. I ended up building a new plate holder that pins in to the hitch
jman86
jman86
Thanks, I agree it sits to low, do you have any pictures on how you mounted it to the frame? I may end up taking that route.
DA67Goatman
Ohio USA
I did not take many pictures. I just cut the endplates off the cross tube and welded 3/4" thick square steel plates with hole in each corner. I ran long bolts all the way through the front frame rails so I didn't have to try fishing nuts down the box section. Mounted it directly between the frame rails with the 2" receiver opening about 4in behind the bumper. I cut out almost as large as the license plate so I can get both hands in to do the hitch pin.
Dean2
Near Edmonton
Do NOT mount a hitch to a receiver trailer mount. While they will work on a straight forward pull, any angle at all is not going to be a good solution. I tried the receiver mounts many years ago and even a 9000 pound winch can seriously f up your mount and what it is attached to. Mount a winch front and back properly if you actually plan to use it regularly or in tough conditions.
jman86
jman86
Thank you goatman, I'm seriously considering doing it that way. I agree Dean2, straight pulls only. You never wanna do side pulls with any winching application ever.
jman86
jman86
Here's a pic of my truck, running kanati trail hog 35/12.50 on stock 20's with 1/4 inch hub centric spacers to clear ksp UCA's. Some don't like ksp brand, but I ran them on my 2017 ram with no issues had them installed over a year before I traded in for this truck. The way the bumper is designed gonna try to make it so the hitch comes out just above license plate elongated opening.
