Fuel gauge quit working. Reads empty
kenishere
Yucaipa
5.9 diesel
Already checked gauges. All worked fine on test. Gauge still reads empty when started
turkeybird56
Central Texas
Wire loose from/to sending unit???? Thinking out loud.....
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
fuel tank sending unit bad
My 2014 has this issue... $100+ for sending unit, $200+ for entire assembly with new fuel pump, plus $400 to install
wgreggking
rural Arizona
2017 4x4 offroad
What he said^^^ . Sons 2014, same symptom, dealer replaced the entire fuel pump assembly.
Work vehicle
Hudson, WI
V6
I have a 2018 Big Horn that does the same thing. Start it up when I know there is gas in it and it dings that it is low and shows the gauge pegged at empty. As I drive it, it fills itself to where it should be. I had this issue last winter and the dealer put a new gauge in it. Worked until the middle of May then on a damp cold morning it started all over again. I think there is a corroded wire or something to that affect. The dealer wants to dump another fuel pump/sending unit in. I hate that they throw easy expensive fixes that don't work.
Thoughts?
RamCares
n/a
n/a
Thoughts?
Hello! Our team would like to offer our assistance alongside your dealer if desired. To get started, please send us a private message with your vehicle's make and mileage so we can take a better look.
Hannah
Ram Cares
