Ross Sampson
I have a 2010 Ram 1500 Laramie, I jumped in today and the truck stalled on me I shut the truck down and tried to start the engine, the engine turned over and over and over but would not start. I played around a bit and finally got the truck running but it is idling very ruff and when I press the gas pedal i have nothing. its is throwing codes for throttle positioning sensor and crankshaft position sensor. Apparently the throttle position sensor is in the throttle body unit, I put a new throttle body on but I am still having the same issue. I was not able to track down a crankshaft sensor today but plan on replacing that as well. Any help or advice would be appreciated and just wondering if anyone ran across this problem. Thanks in advance...
