Gauge Cluster flickering
Chris19
Canada
Hi all, 14 Ram 1500 Big Horn with the advanced gauge cluster. I've noticed at times when I'm driving the centre part of my screen flickers as if my lights are turning on and off. It does it regardless if my lights are on are off and will periodically occur. Unsure what would cause this issue, everything else works accordingly and has been doing this since late summer. Thanks
Jeepwalker
WI
2012 Reg Cab, 4x4
Check:
Bad grounds/Weak Battery/Bad battery connections/Weak charging/Slipping accy drive belt (worn alternator pulley grooves??)/Push down fuses in case they worked 'up'.
:happy160:
thoffmann517
