Gears and posi for 2012
2012RAMMAN
Los Angeles, CA / Mexico
HEMI 5.7
i have a 2012 ram and i want to make it posi do i get the mopar posi unit or yukon and with gears can i fit 4.56 or i can go r/t gears 4.10?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Are you 2wd or 4wd? If 2wd, then you will need the factory LSD unit and the factory 4.10 gears, or you can modify the factory carrier to accept aftermarket 4.10's or 4.56's.
If you are 4wd, then you are going to need a complete front axle from an 09-11 to make the swap up front. Everything I posted above for the rear is still the same for the 4wd.
I have not listed these parts on the site yet, but I can get them for you. Let me know if you are 2wd or 4wd, and I will throw some numbers together for you.
2012RAMMAN
2012RAMMAN
HEMI 5.7
sent u a pm
BigSexyBlue05
2012 dodge ram quad express
Where's the best place to purchase a 2009-2011 front axle
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I would go through our sponsor Factory Mopar.
BigSexyBlue05
Yea just did that. 750. That's not bad. Besides the axle Is there anything else I need to purchase from factory mopar to make the switch so I can purchase 4.56 gears from you
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
That's all you need as far as factory parts. Then you just need the gears and install kits. You are going to have to modify the rear carrier to accept the 4.56's out back, but they will drop right in up front with the new axle.
BigSexyBlue05
What kinda modification on the rear are you talking about?
