Gears....VERY frustrated!
Ramunit
Are you using the stock LSD?
The Assassin
The Assassin
B-more careful, Murderland
Um...I guess. I have to admit, I am not very well versed in the whole gear thing. The truck is an 06 1500 4.7 4x4. So idk if it has one or not?
Ramunit
If you have the stock factory limited slip then the pin will have to be ground, if not then I think you are good to go.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Sorry Dan but this shop that does your work don't sound so hot
joetama
Ohio
Gah I was thinking this but didn't want to say anything... The stuff in this thread seems like something most 'professionals' would know.
joetama
Ohio
Well, no where in the directions did it say anything about grinding anything. And, to their defense, they aren't a 4x4 shop.
Directions? :crazy:
I'm not going to judge... I wouldn't have known that stuff needed ground out till I read it here.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
I was going to suggest the grinding, but obviously I'm late on the scene for that.
Dan...I'm not sure about these guys putting in your gears. If they have to go by directions, what's to say they are going to get them setup right even if they can get them in the housing?
I put 4.56s in my '04 at one point and had a guy do it who never did aftermarket sets (so he did 3.92 and below) and they howled like mad. I know there are settings like backlash and such that have to be right or you will tear the gears up.
Ramunit
I would tend to believe that there is no way of anyone knowing that grinding the housing for Motive 4.56 gears was needed on later model 3rd gen Dodge Rams unless they read the forums on a daily basis.
zack
pa
5.9 cummins ho
Well good luck man ...just as much as that shop gets under your skin I hope all work out for you
bigtigga84
dela....where?
^^what he said man. that's why im gonna go see zack when i can get time to have mine put in lol. how many cases of beer do i need to bring?
zack
pa
5.9 cummins ho
Father inlaw don't drink I will have to ask him what he wants lol
The Assassin
The Assassin
Gears are in! So far so good. Have noticed a significant increase in mpg and low end power.
Sent from my DROID X2 using Tapatalk
sullivan
Houston, Texas
Good deal, make sure they put the right gear fluid and friction modifier in.
nussdawg395
PA
5.9 Magnum
Sweet! Glad it all turned out ok man!
