Got my build sheet
BigBlue05
Eads, Tennessee
I have a couple of questions about what's on my build sheet. The first being did all of these trucks come with auxiliary transmission oil coolers? Also if anyone wants I'll post The whole build sheet.
Edit: I'm just gonna post my build sheet and any input as to what is an extra option from what a SLT comes with would be great.
M9 Cloth 40/20/40 Prem Bench Seat
DV Dark Slate Gray
AFZ Quad Cab Big Horn Value Group
AHC Trailer Tow Group
APAS Monotone Paint
A85P Mutually Exclusive Package
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags
CKES Floor Covering Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMHP 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSAP Anti-Spin Differential Rear Axle
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I69S Route 69 - NS, SHAP, MI
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Air Close Out Panel
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PBJA Atlantic Blue Pearl Coat
QBJS Atlantic Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCV Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WPGP 20X9.0 Aluminum Chrome Clad Wheels
XA8S Non Adjustable Pedals
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U.S. Mkt. Specifications
usaf2006
Augusta, GA
I think they did, but the tow packages has larger ones. I may be mistaken though.
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
Post it!!!
Sent from my SM-G935V using Tapatalk
HemiLonestar
MD
Yes, there were 3 sizes, there is a standard, tow package/standard 2500 (if I remember right) and 1 ton huge. It's rectangular one at the bottom in front of the radiator.
BigBlue05
BigBlue05
Eads, Tennessee
Does anyone know what the A85P mutually exclusive package is? And the next generation engine controller
HemiLonestar
MD
NGC, it's the generation of engine controller (PCM) you have. The other one I'd google the sales code and see what it says, or you could ask a dealer.
