Whatishappening10
2012 Dodge RAM 1500 55k miles.
About 2 weeks ago I noticed a grinding/rubbing sound coming from the front drivers side. I inspected the breaks and they were worn and needed replaced. I had my mechanic replace all pads and rotors as they were needed. When I drove my truck home the sound still persists. There is a low grinding noise when driving straight at about 20mph any faster and you can't hear it. (Not sure if it goes away or if the wind noise becomes too much) After driving for 15 minutes the sound goes away. I believe the sounds is correlated to wheel speed not the engine speed or rpm.
I don't believe it's my wheel bearing because there was no play in the wheel when jacked up. Also I cannot replicate the sound when the truck is on the jack. Also turning the wheel doesn't effect the sound.
I have only driven the truck home and haven't moved it in fear of causing more damage. When I got home (about 30 miles) I could smell slight burning around the front drivers side, could this be from the fresh breaks?
Could it possibly be a u-joint or CV-joint that is going bad? There is no ticking or clunking, just some rubbing/grinding. Also do I need to look at my differential?
