Thelegendl23
So after assuming It was the LEDs, spending hours and hours swapping different combos of ballast, ant flicker and bulb, bending pins in my connectors to ensure good connection and the list goes on. Turns out there is a solution that if you're having these symptoms it will resolve the issue.
One side randomly not working and it can't be replicated with stock bulbs, as soon as a higher power bulb is installed it will either not work at all or behave very strange flickering staying on and shutting off etc.
Here is the fix:
Jump the grounds together (middle black wire both sides) and add a quick disconnect for easy removal.
Hours of trying and it was that easy.
Here is the fix:
