Heavier coil spring lift?
Vermont
I have a 1994 Dodge 1500 that is sagging, looks like just old springs. looking for pics of half tons with 3/4 ton or 1 ton springs in them
CountryBoy4598
Vermont
If I use v10 springs and want it nice and level do you think I'll need some blocks for the rear leafs? Or add a leaf or two?
Hunter_5.9
South Carolina
I have 2500 springs in my 5.9L it lifted the front 2" I'm clearing 35x12.5r18 nitto mud grapps no problem
2001ram15004x4
Coils
I currently have my rear end 3 inches higher than the front and the front has coil spacers so what im wondering is can I get skyjacker 3 inch lift coils with my spacers to lift the front end up? Or do I have to change more because im making the front end even higher?thanks
Johnn123
Ontario
You cannot add anything to your front end with out major changes. You should NOT ever stack a coil spacer on a lift coil, regardless what anyone who's done it says.
You probably have sagging springs which is why your front end is so much lower than the rear. Do you have anything added to the rear all?
2001ram15004x4
I have some blocks in the rear.. So can I take out the coil spacers and put lift coils and if I do that what else would I have to change?
2001ram15004x4
Do you guys think I can fit 35s in the front? This is how much room I have
2001ram15004x4
After I remove the block in the rear Id like to try some 35s but im worried of rubbing in the front
OasisNinjaBat
