OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Location
- Philadelphia, Pa
- 2020
- Hemi 5.7L
Ok so I'm getting ready to build a new set of retrofit lights and I need to solve this issue before I even begin building them.
So, long story short, I sold my custom built 13+ projectors and my friend lent me a set of quads to use while I built my new set of lights. The passenger side low beam kept going in and off and eventually the high stopped working too. So I pulled the headlights to change the bulb and found out that the H13 connection from trucks harness to the headlight housing was faulty. I would shake and move it and the low/high would come back on. So I went and bought a new H13 female from NAPA. Cut the oem off and soldered the new plug on. Problem solved for a few days. It goes back to being out. I take the headlight out again and move the wiring around and it turns on and off. So I figure the plug on the headlight side is faulty/pins are bad or bent. I wrap a ton of electrical tape around the plugs and that fixed my problem for about a month.
So yesterday I got a new set of quad headlights. Brand New. Put them in, low and high work. I shake the hell out of the plugs and the lights stay on. Success I thought!! Nope, today, the low and high are back to being off. If I smack my inner fender liner a couple times, the light comes back on. But then goes off after driving and I guess movement.
So my question is, wtf is going on here? I've already put a BRAND new Female H13 plug on the truck side harness. I just installed brand new Quads, which have a brand new H13 male plug on them. Why am I still experiencing a bad connection at that point?
And I know it's at that point because when I remove the headlight housing and I bend the wires at both sides of the H13 connection, the light goes on and off.
What is even left to do here? Should I try replacing the truck side Female H13 again? Perhaps the one from Napa had loose pins inside? I've tried pushing the wires into the plugs to make sure the pins were seated properly but still no luck. I don't understand how with 2 new plugs I still have this issue.
Any help would be GREATLY appreciated!!!! Thanks in advance!!!
Sent from my PH-1 using Tapatalk
