Hemi Motor TRQ Specs
Discussion in 'Engine & Performance' started by KGBIGCOUNTRY, Apr 24, 2013.
Sponsored By: Moe's Performance
  1. KGBIGCOUNTRY
    KGBIGCOUNTRY Senior Member
    30
    13,314
    382
    MECH, VA
    Ram Year:
    2004 RCSB/2005 QCSB
    Engine:
    5.7 / 5.7
    Here is the list for everything you need to TRQ your Hemi correctly
    On a few its done in steps so its listed 1) 2) ect
    Few of the bolts are also TRQ to yeild as the last step
    Cam Gear bolt- 90 FT LBS
    Timing Set bolts- 21 FT LBS
    Rods- 1) 45 FT LBS 2) 60*
    Mains M-12- 1) 28 FT LBS 2) 90*
    Mains M-8- 1) 16 FT LBS
    Main Cyclinder Head bolts- 1) 25 FT LBS 2) 40 FT LBS 3) 90*
    Small Head bolts intake side- 1) 15 FT LBS 2) 25 FT LBS
    Rocker Shafts- 195 IN LBS
    Damper- 195 FT LBS
    Exhaust- 23 FT LBS
    Intake- 9 FT LBS
    Lifter hold downs- 9 FT LBS
    Oil Pump bolts- 21 FT LBS
    Oil Pan bolts- 9 FT LBS
    Front Cover- 21 FT LBS
    Flywheel- 70 FT LBS
    KIDRR, indy05daytona and Alessandra like this.
  2. FlaglerMegacab4x4
    FlaglerMegacab4x4 Senior Member
    192
    8
    Mar 10, 2013
    Ram Year:
    2006
    Engine:
    Great info man!
  3. LightningRaper
    LightningRaper Senior Member
    28
    218
    155
    Jul 31, 2013
    Brooklyn NY
    Ram Year:
    2006
    Engine:
    Viper 8.3
    Good to know
  4. indy05daytona
    indy05daytona Member
    39
    65
    Sep 6, 2013
    Ram Year:
    2005
    Engine:
    Nice work up
    Sent from my HTC6500LVW using Tapatalk
  5. Statcher1
    Statcher1 Senior Member
    29
    4,255
    2,245
    Nov 2, 2013
    Kentucky
    Ram Year:
    Engine:
    Nice list man.
Share This Page
