Recently upgraded my low beam Halogen Projectors to a HID kit that I sourced through:
https://headlightrevolution.com/200...adlights-upgrade-low-beam-hid-conversion-kit/
My driver's side halogen low beam burned out and figured if I was going to take part of the front end apart I would upgrade if feasible meaning clean install, integration with CANBUS, and effective light that is not obnoxious. Headlight Revolution recently came out with this kit which eliminates the resistors with these new Ballasts made by Hilux. I went with 35 watt ballasts and 5000k HID bulbs.
I bought my pickup used and assumed I had the factory 55w bulbs so while I didn't think they were great, they were tolerable with the fogs and Auto Hi beams. Lone and behold when I took the headlights apart it had upgraded 65 watt bulbs which I guess by mileage didn't get much longevity, 10 to 20k at most.
The HID kit is totally plug and play, lights up the world without being obnoxious (no one flashes me), should last longer. I'd compare the upgraded lighting to a good german car as they typically use 35 watt ballasts and are 4300 to 5000k in lumens. Definitely money well spent.
