High beams won't turn off
wedinchi317
Colorado
I have a 2011 and lately when I turn on the headlights, the high beams turn on (whether the switch is in the high beam position or not). The only way I can get them to turn off is to pull back on the multi-function switch and sometimes that won't even turn them off. Even if they go back to default, two minutes later the high beams turn on again. I was going to just replace the multifunction switch but wanted to get your opinion before I went and spent $100 on the switch. Thanks.
rule18
Admin
Administrator
NY
2017 Rebel
@wedinchi317 welcome to RamForum. I agree with the MFS replacement (I had to replace that in each of my previous trucks). The only other thing that comes to mind is an intermittent light sensor (if your truck has one) but that's a really remote possibility. Good luck, and report back what you find.
