High idle
BrittRose
V8 5.9L
97 Dodge Ram 2500: code p1294-target idle not reached. Trucks been idling at about 2000rpm for a couple days when it's in park, if you change to drive it drops some but still high. Checked for vacuum leaks last night, but didn't see any. Today, changed pvc sensor and also crankcase breather cap. Suggestions? Thanks.
Bigdaddycodes
Swift Current Saskatchewan
This post should be under second gens, not 4th gen performance.
But as for your problem, check the throttle and see if its sticking, clean the throttle body.
Orca
