rroche1982
Looking at buying the limited panels and dash. I know the panels are very easy, but how difficult is it too change out the dash and console?
i think the console is the same, but i need to swap the lid, and entertainment bezelWhat all do you want to do to the interior?
By dash, if you mean instrument cluster that is simple.door panels from a Laramie which are easy
my question is mainly about the dash and console swap
I have a big horn, I think the only thing i need to change is doors, dash, console area so it looks right.....or at least that's what i can remember from my last Laramie
The dash is not a hard job but it will take some time to do as you want all installed correctly the first time, this is not a job you want to do twice. I recommend that you have some help with you when doing this. Four hands are much better then two with this.
As for the console, its a simple bolt in. No cutting or drilling required. Just install the seats last after the console is installed and all electrical parts are tested.
If you have questions during the install you can always PM me, I usually reply fairly quickly. Have fun![/QUO
So is the dash about a day job or so?
are the crew cab doors in a 1500 and 2500-3500 all the same? looking at buying panels from a2500 i have a 1500I spent one morning taking all apart then most of the next day putting all back together again.
Yes, all the same.
Thank you
