Great writeup on the pdf, I saved it and going to do a bit of a study on the air system, Im in the process of buying a new 2023 Limited, Im proficient with air systems and I know how to care for them, the question is do I want too, I can order a truck and delete on order, but how long is the wait, I can go and see what stock is available, there will be way more Limiteds in stock with air, I also want Ram boxes, if this was the case, I would move the breather and exhaust tubes out of the taillight compartment and into the Ram box via drain hole and modified drain cap, this makes the accessibility much easier, I would love to relocate the compressor into the Ram box but that would become a heat and warranty issue, I can take care of the heat and grounding issue, but then again if falls into the warranty trap, day one of truck delivery, at home I would go behind tail light and put some anti seize of the air filter/somewhat of a dryer, metal blocks and joints would be treated to make them more corrosion resistant, and periodically re-treat, there are much better air dryers out there that can be put inline, but again what about the warranty, I love everything about air ride, but should I wake up in the morning of purchase day and say to myself, do I feel like caring for air ride and mostly, do I feel lucky.
