DMart03
trying to get a new rear end for my truck but i'm having some problems finding out what my rear gear ratio is. i've looked all over...cleaned up the rear pumpkin and found some serial numbers but haven't had any luck matching them to anything. in my trusty haynes manual it has a picture and shows you how to identify your axles. my axle model is 35...then right above that is reads 0639, i'm guessing this is the identification tag????? i don't have a limited slip tag. the plug reads 72-2 3723687 99201 and on top of the differential on the right side it reads GSC 5 and on the left it reads 520694319056 and the right clamp reads APO 799 S. VIN # 3B7HF12Y1XG208341
this isn't even the bad part...the rear end that i am trying to pull from another truck has less information than this...so i need some expo advice on how to tell what is what with the gear ratio. as always, i appreciate the help
