AllMoparParts.com
- Benny
- Apr 9, 2013
- 2,590
- 627
- All
- All
I believe I have seen it mentioned somewhere in this thread as being an issue with the 4c upgrade.... and I believe a few have had success with replacing the camera with a newer PN version from a 2018/classic 4th gen. (Not sure what the newer camera pn is, vendor @AllMoparParts.com can assist with that).
The 2018 Camera # is 68274731AE however this is the same from 2016-2022. I did come across this tech tip as well
Tech Tip Part Description: Rear View Camera
Tech Tip Description: In the case for inoperative camera, radio screen unresponsive, blank or black in reverse mode. Before replacing the camera, update radio to latest software available, give radio a sleep cycle; (disconnect the negative battery terminal and wait 5 mins), log any DTCs, check for proper connections and reconnect camera before proceeding with replacement. If function is restored with camera replacement, re-install original camera to verify its non-functionality.
-Benny
