Hey everyone, im just adding my 2 cents to this, if it helps anyone.. I purchased an ebay UAQ that came out of a 2021 Charger. Trying to find one out of a RAM was getting cost prohibitive . The one i found I got it for a great deal, it has a small scratch, but its basically not visible.. I said what the hell, let me try it out..It was NOT a direct fit, but it was easy enough. Some people will cringe at this, but at some point, you just do what needs to be done!! I basically used some snipps and had to remove a few of the cast metal mounting tabs, as they dont match up to the truck screw mounting holes, and also, they would not let the bezel snap into place.
Now, The only thing holding the radio in place is the bezel, but, it has not moved at all, doesnt vibrate, and its solidly in there..It takes a bit of finesing to get everything back together, but its pretty easy..For the amount of money saved, it was worth it for me to go this route...
Everything on the radio works 100%, (except the soft buttons for seat heaters..but thats a given for any of the radios..) so to get those soft buttons to work, I purchased the heated seat emulator C-INT4CK from infotainment.com, which is the exact same thing as the Jailbreak Enzo from Customtronix..Now, I did have some issues with the infotainment unit, long story short, the unit would not activeate the soft buttons..tried to get help with their techs, they arent that helpful, and Idont think they really know what they are doing when it comes to the Enzo. Its impossible to contact them via phone, and emailing back and forth gets frustrating...I finally reached out to Magnus at Customtronix, he immediatelly sent me a firmware update file, and all was good..If any one needs to go this route, just buy directly from customtronix and save the headaches!
Now to get android auto to work!
I purchased the usb media conversion harness from MpGrimm2, which worked great! I was looking around for a media hub, and again, on ebay i found for really cheap, a media hub out of a Alfa Romeo Stelvio..It seemed very similar in size to a Ram one, so again I said, what the hell, and i bought it..low and behold, it works!! kind of...lol...when i plug in my phone, it quickly goes to Android Auto, and all functions are good and correct..the issue is, at truck start up, if a phone is not plugged in, the radio screen has a window pop up that says "media hub not recognized" or something along those lines..as soon as phone is plugged in, it goes away and all is good...Maybe someone knows how I can fix this small issue? But all in all, for less than $600, Im prettty happy, and really enjoy having the AA avialable for maps/navigation...
