Hurricane durability questions?
Poram
Ok so both the Hurricane I6 engines, (SO & HO), have an aluminum deep-skirt blocks with Plasma Transfer Wire Arc (PTWA)-coated 3.31-inch cylinder bores.
Don't Chevy, Ford and most other manufacturers use the ductile iron liners in their performance vehicles?
(I'm just playing the Devil's advocate here but hope this scenario doesn't go down like the Chevrolet Vega's ill fated aluminum block engine without iron liners.)
That said, I had entertained the thought of upgrading my low mile 2016 Longhorn but I think I'll sit this one out for a while.
Your thoughts?
tron67j
Maryland
Your thoughts?
Getting in at first has pluses and minuses. I would think Ram did their homework enough to not put a troubled engine in, that would be disastrous for them. But having it at first gives you both warranty and the chance to sell for a better price if you jump out early. What I mean is that if there is a bug to work out, you could sell or trade early enough that the full impact to used value wouldn't have hit much. That may sound a bit messed up, but is a way to consider upgrading now. Good luck.
Dodge 1500 4X4
Rochester, NY
Ferd did the Plasma arc lined cylinder sleeve bore, W low tension piston rings, on the 2018 5.0 cayote for it to be an oil pumper and use a Qt of oil every 2,000, there fix was to give you an upgraded dip stick W hash marks moved and told customers to add another Qt of motor oil when refilling.
P
Poram
Good comments. I'll probably hold off for a year or more on upgrading.
I guess a person could always opt for an extended warranty for peace of mind.
:hmm:
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I’m thinking time will answer your question. I never buy a new engine in the first year.
I understand the sentiment, and would tend to agree. But it's not the first year for the Hurricane engines. They're on their second year in the Jeep Wagoneer and Grand Wagoneer. You could say the 2025 Ram will be the third year for these engines.
Tonysr
5.7L
From what I read and was told by local dealer, they haven't seen problems with the Hurricane engine in the Jeep Wagoneer but like with anything even the Hemi didn't have problems until they went to Cyl. deactivation. My 2005 had no engine issues even at 250K miles.
Dusty
Rochester, New York
Durability issues usually don't show up in the first through third years of production, but especially in the first year. Of course its mileage dependent as well.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 108005 miles.
rvance
Pent 3.6
I understand that they have been used for several years in BMWs. Not that I find that promising. I would wait.
farout75
Laurie, MO
5.7 L
Your thoughts?
Frankly, a 3.L engine with twin turbos is pushing all the HP and torque out of a small displacement engine can deliver. It barley gets much better mpg as the 5.7. What's the point?
chri5k
USA
Diesel
If the PTWA on the bores is like the Ford, it is around 0.004" thick. Seems like the block is basically trash if it gets a nick or gouge in the cylinder wall. I suspect few shops will have the specialized equipment to re-coat the bores. I guess you could increase displacement by boring it 0.002" over. :D
That and no oil dipstick, it seems like this is designed to be a disposable engine. At great expense to the unlucky owner.
Daw14
Will these be like a real hurricane ? In the news when new , then destruction , then it just falls apart into pieces ? Who pays for a new engine when that sensor fails ? My 2014 had a failed oil pressure sending unit under 8,000 miles and 6 months old.
Sherman Bird
Houston, Texas
Porsche has used coated aluminum cylinders for years with good results. Ford owners and Porsche owners are lightyears apart in terms of diligence in being sticklers for timely maintenance.
There! I diluted the mix with a douse of water! ;)
ramffml
ramforum
MDS is not the problem, it was part of the very first hemi even back in 2005.
Kickboxer
ND
5.7 Hemi-non-Etorque
Emmisions, a common reason, well known for several years.
DILLIGAF
Canada
Dodge and Durability dont go in the same sentence...lol...
