Hvac help, PLEASE!
aatonytone
Recently my hvac stopped working, no air at all but the controls seem to me recognized. I have a 2013 ram laramie with dual climate control. I have replaced the resistor, the blower motor and the hvac control module. I feel like its a simple relay or something iveI checked the fuse even replaced it. I dont believe its the control switch because the screen still operates the hvac without issue. Just nothing is actually blowing. Any suggestions would be greatly appreciated.
A
aatonytone
Still have this problem and I'm going into summer, no A.C now
Someone has to have an idea of a fix. The internet fixes everything.
Ricks Ram
You have pretty much replaced everything that may have been causing your issues. I haven't seen this one before. If you haven't already I would start checking all if your wiring for any possible damage. You can also use a multimeter to see if you are getting power to the resistor or blower motor when you try to turn on the fan. When you turn the fan speed up or down with the dial does it reflect the changes on the 8.4 screen? You may want to invest in the alfa OBD app to help diagnose the problem. Besides enabling codes it's also a great tool to show DTC codes.
RamCares
n/a
n/a
Hello aatonytone,
We're sorry to hear this and understand your desire to reach a solution. Are you thinking you'd like to visit your dealer for an official inspection? If so, please send us a direct message as we'd be glad to escalate to a case specialist for further handling.
Jasmine
Ram Social Care Specialist
