Icon reservoir mount front coilovers.
Nick@GotExhaust
Preferred Vendor
SC
We sell a lot of ICON coil overs. Feedback is always very good with them. I wouldn't hesitate to get an ICON coil over. We can offer a great price on those. Message me if interested
crazykid1994
Those are 7-9” lift for a ford. You may need to look into custom length to properly get your desired lift height.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
His Dana 60 solid axle is from a F250 from a previous post
RedSRT is correct. My front Dana 60 is from a 2007 superduty. Hence why I’m looking at the Ford coilovers. Truck is on jack stands at ride height now. Old coil buckets are cut off and ground down.
Will be using ballistic fabrication coilover frame mounts.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
As far as I can tell, bilstein has a patent on the 7-9” Icon superduty coilovers. I do not believe Icon can sell them. Only Bilstein.
Nick@GotExhaust
Preferred Vendor
SC
There is always a "Custom" length option
novelmike
Central California
They’re currently listed for sale on the Icon website.
Why would Bilstein have a patent on that particular size shock that’s made my Icon?
Do you think you’ll me running into a ride quality issue putting a coilover that is made for a superduty on a Ram 1500?
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Thanks I’ll have to check their site again. Didn’t see them on there.
As far as patents go, I have an acct with Icon, and when I was going to have remote reservoirs made for my ram 1500 12” lift kit...Icon was going to assign me a number so no one else could use it.
That’s what so assumed bilstein did.
As far as ride quality, I’m going to weigh each corner to determine spring weight Before I order.
I was quoted at just under $1,000 each for custom length, adj compression resevoir Icon coilovers if I remember correctly.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
1000 a side isn't bad for all the custom measurements and work going into that beast
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Not at all. I’ll have to call Icon and ask, but I’m pretty sure my cost included adj compression reservoirs. Another reason I am going with Icon, is because they use zinc primer, then powder coat their springs. Fox does not, that’s why the fox springs rust after one salty winter.
