Ignition and nothin but click
shicksjr01
Madisonville Ky 42431
Well truck at dealer. 2013 ram 1500 cc w/ 5.7 hemi and got in it this weekend and started it and nothin but click 3 times and then she started. New Battery a month ago and took to auto place had system checked thinking maybe a starter but all checked good. They suggested dealer due to ignition switch TBS issues, so that's why its there. Will see what they come up with.
Perseus
North Dakota
5.2 magnum
Cable corrosion and or loose terminals or system ground to block and or chassis. Truck sounds new enough that none of that's really likely but I've seen stranger on newer.
Alternator may not be charging adequately but if she cranked over and fired up on the 3rd try. That sounds more like an intermittent connection issue.
RamCares
n/a
n/a
Hi shicksjr01,
Sorry to hear about this! If you need further assistance during your appointment please send us a PM with your VIN and let me know.
Andrea
Ram Social Care Specialist
shicksjr01
shicksjr01
:(Well Dealership had it overnite. By 900am they were calling. Could not get to repeat click so nothin wrong come get it.
KansasArt
Kansas
The first sentence in perseus reply. Check those and the battery terminal connections. Especially since you just installed a new battery a month ago.
The click should let you know it isn't the battery. But for giggles, if it happens again did instrument cluster light up when trying to start it? I agree with Perseus, likely an intermittent issue from corrosion or loosened connection somewhere.
a couple thing to look at says these guys, ignition switch or transmission not reading park. I would be using my e brake all the time for sure.
shicksjr01
shicksjr01
I had the company that installed battery do a system check and inspection and alternator, starter and cables and connectios good. Can i order ignition switch and replace it without reprograming key phobs?
I don't have the answer for that, but my guess the new switch wouldn't change the way the FOB is read, so I would guess yes. No flash likely necessary either.
twolabsdad
Diesel
Look in the fuse box under the hood. Press down on all of the fuses and relays to make sure they are in correctly. Also if a relay is discolored or looks like it could have gotten hot, look up what it does and possibly replace it. Unqualified two cents here but sometimes simple works.
Perseus
North Dakota
5.2 magnum
Any good , competent locksmith can swap out ignition switches pretty quickly and reasonably.
The folks in my neck of the woods can usually flash fobs if necessary, I would imagine the same is true for you. NAPA likely stocks that switch.
Not plugging for them , just been my experience.
